However, usually a thinner tire and slim LP sidewall would not be great for jumping, but the Katar tires seem to have enough give and softness in them to help on impact.
I don't really use the Katars (er... didn't?) use them for jumping, but they were absolute MONSTERS in the grass/gravel. I was incredibly impressed with their performance considering they're a stock tire.
Did you check out GPM, as they also make aluminum diff cups & better pricing, especially if you do all 3
I just looked, and then sat there a bit sad that my HR cups came in today.
Are your Badlands premounted on 3.8's?
Negative. They were purchased pre-mounted. I wasn't quite comfortable with balancing tires just yet, since I'm only about 2 months back into RC after a 20 year hiatus. I think the next tires I'll pick up will be the terrain crushers, then possibly some unmounted Badlands that I can gorilla tape the liner to help prevent ballooning.
I went with RPM rear skid plates for both my Talion/Kraton, as they are also quite light.
My chassis has definitely seen some beating so far, so I was a bit more interested in the protection that the aluminum skid plates will provide. Those truggies sit awfully low. I've upgraded to Tekno orange springs, so it will definitely sit quite a bit higher. Perhaps a bumper solution would work properly.
