Hey all, could someone give me an accurate dimension for the diameter of the handles on mip metric hex drivers please, as in what size hole would they fit through?
What do you mean the shaft length? The actual plastic handle size? Shaft width? Here's some pics but again not sure what exactly your asking?Hey all, could someone give me an accurate dimension for the diameter of the handles on mip metric hex drivers please, as in what size hole would they fit through?
nice on thanks, just what I was after.. got some on order, just need to drill a few holes on my tool stand for them to sit inMy calipers read as follows for the largest part of the handle:
2.5 mm: 22.15 mm
2.0 mm: 22.60 mm
1.5 mm: 19.25 mm
Thanks for reply, I thought "Handle diameter" was easy enough to understand.. got the details from OP and your pics of handle width.What do you mean the shaft length? The actual plastic handle size? Shaft width? Here's some pics but again not sure what exactly your asking? View attachment 145052View attachment 145055View attachment 145060View attachment 145064
