vpr5793
- Mojave
Is anyone running the Castle MMX with the Arrma 2050Kv motor? I started having problems with the BLX185, so I swapped out to the MMX and Castle 1515 Sensorless from my Emaxx. I noted that the 1515 gets plenty hot under the stock gearing, so I am in the process of converting the 2050 to 6.5mm bullet connectors.
Is anyone else running the MMX w/ the 2050Kv? If so how does it run?
