bicketybam
Back from vacation!
- New Milford, CT
- BigRock 4x4
- Granite
- Infraction
- Kraton 8S
- Kraton 6s
- Kraton 4s
- Mojave
- Notorious
- Talion
- Typhon 6s
Just got done running my new Kraton EXB with the Castle MMX8S/1717-1650 Kv combo and a 23t pinion. I set the motor temp cutoff at 180 degrees. It took SIX MINUTES to have the ESC shutdown for motor over temp. I waited somewhere between 8-10 minutes and started it back up. The motor was at 138.4 degrees and it took 3 more minutes to hit the cutoff again. I am extremely disappointed. I called it a day and pulled the logs.
Motor Max Temp: 170 degrees
ESC Max Temp: 198.3 degrees!
I got 9 minutes of runtime. NINE. My battery was at 3.79 per cell so that should give you an idea. I am going to post some graphs.
This is the motor temp:
Next is the ESC temp
Finally here is both temps combined with my throttle inputs. As you can see, when I started hitting it, the temps climbed quickly:
Ambient temperature was 81 degrees with 67% humidity.
If you opt for this setup you will have to run fans. I am really surprised that this 8S ESC/motor ran as hot as it did. We are talking about a combo that is close to $400. Maybe I was expecting too much. The performance is definitely there but color me nutty, I would like more than 9 total minutes of runtime. Is that too much to ask?
