I took out a brand new mamba monster 1717 combo for the first time this weekend. I designed a fan shroud and I wanted to check its performance.
Then I downloaded the logs and the motor temp was only reading 1.9 F and the readings didn't change at all. (it was about 45 F outside) . All the other logs were reading as expected.
Has anyone gotten motor Temps logs to work with this combo? I am using the sensor wire in sensored mode with the temp logging option checked...
