Theofanis
Hello, today i calibrate my mmx8s maybe wrong, because as the instructions say
If you are using a Futaba-made transmitter, you will need to set the transmitter’s throttle channel direction to the REVERSE (Rev) position. This is either an external micro switch on the transmitter or an option available within the computer programming of the transmitter. Please start by zeroing out any throttle trim that you may have set in your transmitter.
something I didn't do with my futaba 3pv...
I started with ESC calibrate and i think i did the steps wrong when the esc flashing green i set to full brakes and when it was red full throttle... despite exb is moving in the right directions but manual says If the motor is spinning in the right direction and the green LED is blinking, then you are ready for a test run. Well mine flash red when i go throttle and green when brakes... :/
So i thought to send email at castle and reply me very fast, you will need to reverse the throttle channel in transmitter. Green should be forward, red for brake/reverse. After this, if the motor spins the wrong direction go into the ESC programming and reverse the motor direction.
So i went in my futaba transmitter to reverse the throttle channel 2 and this is what happen every time i set it...
(castle hasn't answered me yet..) the sound comes from motor and it try to turn around (?)... my futaba also everything is in default settings i don't have change something to any throttle channel, any idea what is this and what i have to do to fix it ?
Thanks
Thanks
