Jluther@becoinc
- Senton 6s
- Talion
You mean RPM? There is this but it is for the 8s cars https://www.rpmrcproducts.com/shop/...amba-x-8s-esc-the-arrma-kraton-8s-outcast-8s/Ok,so I got the mmx8s mounted in my ELWB TALION EXB but can’t come up with how to mount the switch. At some point I saw a mounting bracket that castle makes but I can’t find it again.
Have you guys got any suggestions or a link to that mount bracket? Thanks in advance
Every time I use the pps mount my esc cage blows apart. So instead I double sided taped it to the esc. 3 outings no issuesOk,so I got the mmx8s mounted in my ELWB TALION EXB but can’t come up with how to mount the switch. At some point I saw a mounting bracket that castle makes but I can’t find it again.
Floating ESC fan holder? The PPS fan mount just goes under the fan and has a tab to hold the switch.It’s the castle floating esc fan holder that’s the problem. I’ve broken everyone I’ve had except this last one because I gorilla taped it.
That pps mount works great. But every time I use it thr castle esc cage breaks. The fan mount is only connected to one side. Thr far side of the castle esc mount just sits on the heat sink. I’ve broken 5 so farFloating ESC fan holder? The PPS fan mount just goes under the fan and has a tab to hold the switch.
Castle esc cage?That pps mount works great. But every time I use it thr castle esc cage breaks. The fan mount is only connected to one side. Thr far side of the castle esc mount just sits on the heat sink. I’ve broken 5 so far
Really? The esc has a cheap plastic cage or fan holder. It’s only attached on one side. The rest of it floats over the esc and isn’t bolted in. Are you just trying to be a D*ck or have you never actually run into this issue?? My buddy and I have gone thru 5 cages/holders so far. In fact he’s selling all his castle sh*t because he’s done with itCastle esc cage?
I literally have no idea what you're talking about. Here is what mine looks like. It clearly has four screws holding the fan down. Not hanging over the edge on two screws at all.Really? The esc has a cheap plastic cage or fan holder. It’s only attached on one side. The rest of it floats over the esc and isn’t bolted in. Are you just trying to be a D*ck or have you never actually run into this issue?? My buddy and I have gone thru 5 cages/holders so far. In fact he’s selling all his castle sh*t because he’s done with it
Here you go also power switch fails constantly.I literally have no idea what you're talking about. Here is what mine looks like. It clearly has four screws holding the fan down. Not hanging over the edge on two screws at all.
8s xlx2 ohh ok I thought we was talking about 8s esc
Oh XLX2…I’ve used bashers queen and pps on xlx2 they haven’t failed. But the castle esc holder keep breaking. 1100 Kv and 800 kv. Mamba monster x 8s. I put gorilla tape on it to hold and place and that’s worked. Castle needs to fix this BS.
You not doing 60’ landings then. I have 1” foam between it.Oh XLX2…
I have five MMX8S and two XLX2 and all have the PPS mount and NONE have had a single issue. They have been crashed way too many times at over 130mph and still perfect.
