I think the traxxas adapters would fit 17mm ask @razorrcIm ready to upgrade stock tires to mx28 2.8 proline badlands. I was going to order hot racing 17mm hexes but cant find product atf117xt02...any suggestions on what mods I can make for mx28 wheels to fit?
Has anyone tried the proline raid mx28 with removable hexes...apparently you can use 14mm hex adapter PRO634700
Ok great...assuming the same wheel nut and axle will work...was afraid axle would be too short with extension of hex hub?
It works with the stock parts on my BRCC
The Pro-Line website even specifically mentions the Granite
https://www.prolineracing.com/accessories/6x30-to-14mm-hex-adapters.asp
Which hexes are you talking about? The 14mm that come stock? They’re better than the hot racing ones IMO. I’ve read of people having problems with parts of the 17mm hot racing hex extenders coming loose and backing out even when using blue Loctite. Haven’t had any issues like that with the stock parts.
The Pro-Line adapters seem fine.
Read this thread and others for Info on the typhon arm upgrade.
https://www.arrmaforum.com/threads/tips-from-a-new-brcc-owner.22318/
