Right on, those look sweet on there.
Temp gun is a very good investment,should also monitor battery temps,that will let you know if your pushing your battery.I installed some new fans yesterday,replaced the esc fan with a Maclan 24,000 rpm version and these Hot Racing Turbo fans.Will try and give them a try today after work to see if they make any difference!
You could use an angled mount on your ESC fan with the high speed fan you have. It may actually be strong enough to hit the motor heatsink also.
The bearing that failed on my center diff was a Fast Eddie bearing,switched to the stock bearing and no problems since.Gotcha on the bearings. Can you link me to what you are using in the center diff mount and motor mount? I think the Fast Eddie Bearing I put in there, were not seated correctly, and that's why the disintegrated. I have the stock in there now, but will want to swap out soon enough.
And the Stainless Cap Screws add some seriously useless Bling to the car.
Right on. I will be watching the center bearings closely. And since I do run in some loose sandy dirt, I will watch the Hub Bearings too. May have to stack a set of Avids in the Amazon Cart.
Are you sure your truck has seen dirt?That is one clean Kraton!View attachment 6526 View attachment 6525 I'm making some molded wheel wells that fit my lexan body. I'll be attaching them to the existing side plates with black anodized Chicago Bolts/screws .I'll use maby 3 per side. I matched the rear swing arm mudguards to this pattern also . The pattern goes well with the overall look of my truck. I gave up on my order I placed for the Outcast mudflap. It has been over 2 months. I made these out of the Kydex material. It should really keep a little more debris out.
