Mojave Mojave back lose any recommendations?
gary.rvp
  1. Kraton 8S
  2. Mojave
Hi I am running 60k front 200k Center 20k in the back. have the stock motor with speed stock gear. and firma 160 amp with a 6s 50C. when I trade to go full gas is go sidewise. and make me go loose I att a video.
I could be wrong but i think you want heavier in the front than in the back.. try 30 in the front and 60 in the back. The fluid in the rear is light enough your just transfering all the power to one side and going haywire.
Somethings not right and it doesn’t look like its the diff oil
@gary.rvp have you had crashes? When did this start? A quick test, swap you front and rear diffs. But it looks like to me that either you have a suspension issue and/or drivetrain issue. I’d go over everything and see if you notice anything abnormal
