Mojave Mojave chassis belt from Scratch
Jalazon
Can someone help me with exact measurements for an Arrma Mojave chassis from Front to back and side to side From its why this point. Thank you so much example using outcast chassis will be in the pictures.
Thanks...
19.5” long 5.5” at widest tapered down to 5”
Thanks dude. Is there any pointers you can give me as far as differences between Mojave and outcasts chassis
Polar opposites. Mojave is the longest 6S and the OC is the shortest.
Look at where the ring gear of the diffs go. That one has a small indent vs the square notched out. It’s not completely flat either. I don’t have an outcast to compare to.
