joebryant1224
Need help have the Mojave exb and having front diff issues and kind of just getting in the hobby. It’s like the front is locking up sometimes just need a parts number to fix the issue.
The front wheels will sometimes lock and then sometimes they will be open like they should be. New to the forum I will try and get it apart tomorrow for better details also trying to make it some what built proof if there is such a thing.Step one - describe the issue.
Step two - take it apart.
It’s new it’s only had 3 packs run through it.Have you previously serviced the diff or is this happening "as it comes" from the factory?
And pictures
View attachment 120516And pictures
You seem to be missing a piece. There should be another star plate.
Same issue all of us had with the rear EXB diffs, broken sun gears. What shims are under the pins of the output shafts?
Mine didn't last much longer on my exb. Arrma needs to go back to the drawing board on these diffs.they are garbage in my opinion. Got my truck up and running two weeks ago and had to build both diffs already and hard to find parts for right now.
I've tried shimming them a few times and yes I beat them hard but all my drag builds are beat alot harder and only busted a couple old style gears. Plus parts are hard to find right now and the last thing I want is to push a 1000 dollar arrma around because it has no diffs in it.Properly built and shimmed the 29mm are the strongest 6S diffs they have ever built. Looks like a combination of assembly errors and people being super hard on them to me. Most people I know with a recent EXB have not had an issue.
Including my son.
What shims are you using? I ask because there are a lot of ways people have shimmed in the past.I've tried shimming them a few times and yes I beat them hard but all my drag builds are beat alot harder and only busted a couple old style gears. Plus parts are hard to find right now and the last thing I want is to push a 1000 dollar arrma around because it has no diffs in it.
13x16x2 behind spider with and without lsd plates.to much play in spider gears from factory are only just meshing from what I can tell. With lsd added 2 .02 shims to each side and ain't had no issues yet with front diff and removed lsd plates from rear all together.What shims are you using? I ask because there are a lot of ways people have shimmed in the past.
You should get the 12x18 shims instead of the 13x16. They support the sun gear perfectly. Arrma sells them now.13x16x2 behind spider with and without lsd plates.to much play in spider gears from factory are only just meshing from what I can tell. With lsd added 2 .02 shims to each side and ain't had no issues yet with front diff and removed lsd plates from rear all together.
Thanks for the info my friend i will get some coming.You should get the 12x18 shims instead of the 13x16. They support the sun gear perfectly. Arrma sells them now.
