Mojave Mojave EXB hinge pin holders vs blx mojave
Adiabatic
Doing it myself and doing myself in
  2. Vorteks
Only difference I'm aware of is at the front upper hinge pin mount, which is stronger and better designed (less likely for the pins to migrate out while driving) on the EXB. Lower hinge pin setup from the EXB is used on current version of the BLX.
calebgilmore
  2. Infraction
  3. Kraton 8S
  4. Kraton 6s
  5. Mojave
  6. Notorious
  7. Outcast 6s
  8. Senton 6s
  9. Talion
  10. Typhon 6s
  11. Vorteks
  12. Voltage
An alternative to m2c that i've seen and bought a few of here recently have been the treal lower hinge pin blocks. roughly $50 gets you all 4 and you run an exb front upper rear block.
TL01magic
I only see listing for the Kraton 6s, are they same hinge pin blocks as the Mojave?
