I think my son has a mini parachute that goes to one of his toys you could put on your batts to help you out during ejection
How about some dual lock under the batts as well as the straps.Oh and I added two more lipo straps. Hopefully the lipo eject button is held in check this time
Yep that’s probably very sound advice. I have some lipo wrap coming so I can put another layer of wrap around the packs. You know, pretty much for nothing because they never go ANYWHEREHow about some dual lock under the batts as well as the straps.
I have two sets, so the first set is getting sent. If that doesn’t work well, I will buy a tire lathe and turn them down some. These are some thicc boisLooks great!
Are you going to trim down the foam at all? Would be an expensive loss if they chunk, although I have seen James running on some sketchy foams at 170+ speeds without issues.
That’s not the point sir.@jondilly1974 OMG, just buy a Felony already, and get that poor Mojave in the dirt! Those tires do look pretty freakin' cool on there, put a little wax on 'em and you could use it to buff your car!
Definitely "going bananas". Look super sweet JD. Hope they hold up and help you get those numbers you deserve.Got my Gone Bananas Racing Skinz tires today. These were skinned on my old GRP 1:5 wheels. They look pretty bad a$$.
View attachment 163178View attachment 163181View attachment 163184
Thanks brother. I geared down 5 teeth since my last pull to get used to the foams before I push them too far. Hope they hold up as my only other option is going back to 1:8 wheels. I just love the look of the 1:5 wheels on this BDefinitely "going bananas". Look super sweet JD. Hope they hold up and help you get those numbers you deserve.
That is one sweet rig there!!!Got my Gone Bananas Racing Skinz tires today. These were skinned on my old GRP 1:5 wheels. They look pretty bad a$$.
Anxious to see the results. I agree the aerodynamics will be a large limiting factor for this rig, but still would expect you can go much faster given what people have done with Infractions (shaped like a brick)I’ve found that the calculators aren’t very accurate for this setup, probably due to the poor aerodynamics of this huge thing. But I was really surprised not to see higher amp loads indicating this. I have a nice range of gears on the way and will be able to make infinite selections soon. I will have every gear from 29T to 39T and will be able to swap spool and motor gears accordingly.
At some point I’m going to have to address the massive downforce of the dual wings. Maybe this is a case for the dual motor setups where more power might be really needed. I still have a lot of work to do before I max out this 2028 can, then I have a TP 5680 ready to go to see if I can get beyond the 2028 PB, then who knows. I would love to get to the 50’s. I am pretty sure it’s a reality. Just a matter of time and effort.Anxious to see the results. I agree the aerodynamics will be a large limiting factor for this rig, but still would expect you can go much faster given what people have done with Infractions (shaped like a brick)
