Hey, sorry to bother you again...Powerhobby dual fan and heat sink combo. Like $23 from their eBay store. It comes with a y harness, plugged it into the receiver, ran the harness under the front chassis brace and ran the fan wiring around and under the esc mount temporarily until I get my other fans. Hardest part is I had to mount one fan then wedge the other in and it pulled down as I tightened. Screw holes are a bit too close but it works
The red connectors are the y harness.
Hey sorry to bother you again. Any specific way/ slots to plug the fans into. 3 pins in the receiver and only 2 holes coming from the fans Y.?. ThanksPowerhobby dual fan and heat sink combo. Like $23 from their eBay store. It comes with a y harness, plugged it into the receiver, ran the harness under the front chassis brace and ran the fan wiring around and under the esc mount temporarily until I get my other fans. Hardest part is I had to mount one fan then wedge the other in and it pulled down as I tightened. Screw holes are a bit too close but it works
Fans are in a work great. Just wanted to say thanks!!I believe it’s the 2 most inner pins on the receiver but you can try it each way till you find which way it works, fan will either run or not, won’t hurt anything.
Not familiar with them. I'll look them up.I’m gonna pick up some dual ntf fans before long, Be cool to see the difference between the 2
