Mojave Mojave Rear Diff Problem Again
Brian65
Illinois
  1. Mojave EXB
  2. Typhon 3s
Posted a week or so ago that my Mojave EXB rear diff wasn't pulling with the front. That happened on 6s. Rebuilt it even tho I didn't find anything wrong. Been running 4s pack for about last 4 or 5 runs. No problems. Tonight put in 6s and within a few minutes the rear diff went south again. Running 30k front, 100k center & 10k rear. Any ideas?
Rolannd
Wisconsin/Illinois
  1. Kraton EXB
  2. Typhon 3s
Did you replace the plates? I had to on my K6EXB and that helped, granted I only ran one 6s pack. My center plates have some nasty grooves on it too so those will get replaced soon too.
Also, you do know there are sides to the plates? Just want to make sure, sharp edges away from the spider gears.
Or grab this set and make the rear an open diff
Brian65
Illinois
  1. Mojave EXB
  2. Typhon 3s
Yep. Replaced plates and made sure smooth side in towards spider gears. Haven't checked center diff plates. Bought truck new about month ago. Wouldn't think rear would be giving problems already. Running the stock spektrum ESC & 2050 motor
RCbuzz
  2. Kraton 8S
  3. Kraton 6s
  4. Mojave EXB
  5. Senton 3s
Can you post up some pictures of all the components in the diff? Is the case in good condition, gear edges look good as well? Not too much play in the outdrives? Sadly some people run into issues right away, a friend lost his rear EXB diff on the 2nd or 3rd pack..
Brian65
Illinois
  1. Mojave EXB
  2. Typhon 3s
Well I found the problem. Motor came loose. I put blue loctite on motor & pinion screws before ever running it when I bought it. Going to let loctite sit overnight this time. Diff seems nice & smooth now. It was rough before & that's when I noticed the motor moving.
RCbuzz
  2. Kraton 8S
  3. Kraton 6s
  4. Mojave EXB
  5. Senton 3s
Glad you found it! (y)
That 24hour set time is crucial.
