Ahh good point. Didn't think about that. Thanks for the correction.Adding pre-load is not the correct way to reduce leaning, while it stiffen the springs, it also raises the ride height, which raises the center of gravity and lowers the roll center. if any it would increase the leaning.
You can reduce it by moving to a stiffer springs and/or moving to a stiffer sway bar, i described the specific parts here.
Okay thank you. Will the stiffer springs affect bashing?Adding pre-load is not the correct way to reduce leaning, while it stiffen the springs, it also raises the ride height, which raises the center of gravity and lowers the roll center. if any it would increase the leaning.
How much difference did the stiffer springs make on your truck?
its definitely more stable and tends to roll lessHow much difference did the stiffer springs make on your truck?
Nice! I might order those springs for my truck, then. I could def use the extra stiffness with all the aluminum I just put on mine. LOL. Thanks.its definitely more stable and tends to roll less
