They look like stock UDR wheelsI know this is a old post, but what wheel is that? Im buying the Hyrax and want those wheels. Thanks
They are in stock, they have 2 listings, one for a set of 4 and one for a set of 2. You just let Arthur know what color you want.
https://www.ebay.com/itm/VITAVON-al...-/284279923193?_trksid=p2349624.m46890.l49286
are those regular sc 2.2 3.0 wheels for the 1/7 hyrax?I put the Hyrax tires on proline SC wheels with aluminum 17mm hex’s. I got tired of waiting for the Vitivons to be in stock
Tires: Proline PL10163-00are those regular sc 2.2 3.0 wheels for the 1/7 hyrax?
Those tires really are amazing imo. I took them off my mojave and tried them on my talion. Loved them so much on the talion the mojave never saw them againOut testing today on the gravel and these Methods are quite fast. What I also like is when getting on the throttle, the truck continues to track straight. The more I drive these, the more I like them.
Not that I'm aware of. Problem you're facing is the 17mm hub requirement and a 2.2" wheel. I'm not aware of a single plastic 2.2" wheel with a 17mm hex. Just about in every situation you're going to be running the 2.2/3.0 combo and searching for tires in that range. If you really want variety in your tire options, you need to get the Motoworx wheels. Just keep in mind you'll be running a wider stance and the knuckles won't be protected on the inside of the wheel.Are there any plastic/nylon wheel options to fit those?
