Topdeck07
Hey all,
I am at a bit of a loss here, as I don't know what would cause this. Got the truck running after a bad servo out of the box and now the rear lower a-arm mount has broken on both sides. My son was driving his car and took it off a small ramp he made, maybe 6-8'' high. The truck was in the air perhaps a foot or a foot and a half. When it landed the right front tire tucked into the wheel well and I knew it broke. Under the truck was the pin that holds the lower a-arm on. On closer inspection, it looks like the plastic piece just broke right off allowing the pin to come out. This also forced the sway bar ball out of its mount as well. I looked on the other side, and you guessed it. Also broke, but hasn't broken bad enough for the pin to come out.
Is this a common problem? The truck has only managed to get one full battery through it. My truck which was purchased at the same time from the same store has had zero issues (so far). I bought this truck after a lot of research and watching videos of guys launching these things 20 ft in the air with no issues. I never would have thought that an 8 year old driving it around in front of the house on 50% power could ever break something like this.
I plan on contacting Horizon on Monday and going to the shop to try and get a part faster than I can order it. Maybe they could also provide some insight on how to replace it as it looks like I have to take the entire front end apart to get to it. What a PITA!
