I'm sure many of you know that DumboRC is or thought DumboRC was a copycat of Radiolink. Well, actually they are a subsidiary of Radiolink. https://www.radiolink.com/DUMBORC
This really means that Radiolink units should have as fast of response time as DumboRC does. The only other possibility is that they use different CPU's or more streamlined code to decrease processing time.
But here is where the fun begins and the real reason for the title, If you use or have a Radiolink, DumboRC, or other copycat receivers (I'll use the R6FG / X6FG as an example) and you remove the plastic housing. If you see a module circuit board like
this one labeled 3081st2v11. Then you have a reciever with a Texaas Instruments CC2500 1mw 100 meter SPI communication transciever. From what I can find so far at least is that the transmitter has a different module in it, probably higher power longer range, but still the same chip. The importance of this is that if you modify the code on the reciever and transmitters control chip you could get telemetry, you'd have to ad sensors too. The other option would be a new control chip board in the transmitter and reciever to add more info. To the telemetry, and possibly for very cheap other than time.
And thanks to the team that is working on the Multiprotocol TX module mainly for aircraft, here is a chart of some of the systems that use the CC2500 transciever
Protocol Name | Protocol Number | Sub_Proto 0 | Sub_Proto 1 | Sub_Proto 2 | Sub_Proto 3 | Sub_Proto 4 | Sub_Proto 5 | Sub_Proto 6 | Sub_Proto 7 | RF Module |
Corona | 37 | COR_V1 | COR_V2 | FD_V3 | CC2500 | |||||
FrskyD | 3 | D8 | Cloned | CC2500 | ||||||
FrskyL | 67 | LR12 | LR12 6CH | CC2500 | ||||||
FrskyV | 25 | CC2500 | ||||||||
FrskyX | 15 | CH_16 | CH_8 | EU_16 | EU_8 | Cloned | Cloned_8 | CC2500 | ||
FrskyX2 | 64 | CH_16 | CH_8 | EU_16 | EU_8 | Cloned | Cloned_8 | CC2500 | ||
Frsky_RX | 55 | Multi | CloneTX | EraseTX | CPPM | CC2500 | ||||
Futaba/SFHSS | 21 | SFHSS | CC2500 | |||||||
Hitec | 39 | OPT_FW | OPT_HUB | MINIMA | CC2500 | |||||
HoTT | 57 | Sync | No_Sync | CC2500 | ||||||
RadioLink | 74 | Surface | Air | DumboRC | CC2500 | |||||
Scanner | 54 | CC2500 |
