Most common used tool?
John1982
Ok giys so ive thought about it and am only going to buy once so ill go with high end tools. The thing is i don't want to buy to many where i wont eve need any on the Krayton but equally i want to be able to do every job if i needed too if that makes sence ( sorry im really shaking tonight but neet to buy 5omorrow)
What would your toolkit look like size and shape wize on the 8s
Aside from hexs, some of my most used items are marine grease, shock and diff oils, needle nose pliers, and loctite.
A solid pair of needle nose plyers are worth their value and fairly cheap to boot.
Get blue loctite if you don't already have. A small dab will do ya.
I recommend multiple sets of bits, and multiple hex-bit driver handles so you don't have to keep changing bits every other screw that you want to remove.
And, a good cordless with a clutch in the 8 - 12 volt range. I have the 8.4v Dewalt that you can ratchet 90 degrees. It wasn't cheap but I am glad I got it.
Bourbon Barrel GIF by Hatfield Media
I use MS Excel everyday, so that's my go to for just about everything.
For the RCs it's been said before - hex drivers. I use mostly Wera. You can get a set Wera driver from McMaster for about $40 and I would put them up against any brand, but there are lots of good brands out there.
Common ones for me are 2,2.5,3mm
MIP 1.5, 2.0, and 2.5mm hex. 5.5 and 7mm nut drivers. I didn't realize how important a 5.5mm nut drive is till I broke mine, T wrenches suck.
A hardware store allen wrench set will cover the rare occasions when you need something else.
You realize tool boxes are money pits in their own right. Mine rivals any truck I own.
I agree with what everyone above has said.
I'll add:
  • A tool for the wheel nuts (hex nuts) whatever size it is. I just use a socket.
  • Side cutters
  • Torch
  • Craft knife
  • magnet on a stick
Not solely for 8s rigs. This is what I use for most of my rigs.
Here's some of what I use.
Plus a Weller 80w soldering iron, snapon(Weller) butane iron, cordless heat gun, +++
Edit: updated photos
