Talion Most Durable Front Bumper: Talion V4 ?
Is there a reason why you've stopped using titanium?
Might give it a try as my Talion's butt is always dragging.
They have 2.5mm*10cm and might get a couple out of those.
I was using whatever the 1/8" steel stock that was available at lowes. I started to use titium in hopes that it would be a bit harder and a bit lighter. So far, even though it may not be top of the line titanium mix, it does seem to be holding up well. I'll know more as time goes on. I only used it on the stampede though, which is my lightest vehicle, but it had the same issue with getting the front/rear all ground down from my skate park. Now it makes bright sparks when it makes contact... probably a fire hazard now. lol!
Drive one FULL METAL Car is not fun.
We need flex. And good dampers. Also Tires.
Guys witt full metall cars cant drive more than 50mph before the cars FLIPS over.
I have seen tooo many extreme Pimped Traxxas monstertrucks in my life.
NO MORE PLEASE :)
RPM
this is one great Company. Without RPM i will quit RC right away.
Castle MMX8, when will the new 1717 seonsored castle motor arrive ?
I have two RPM bumpers now :)
I need wait other parts arrive also.
then i start assemble everything.
i will show couple pictures then also :)
i have change the oils in my dampers to 1000sc
they feel alot better by hand now.
Anyone else ? Shockoil stock is 1500 rear.2000 front?
sorry for offtopic, i need find better threath för shock oils,
Link anyone?
