always.full.throttle
Hi
Soon i will buy one TLR Typhon 1/8 Buggy roller.
I wonder what is the most needed / weak parts you need to have in your pit-box ?
Is there any weak parts thar almost everybody needs change ? and also is there better aftermarket parts for these parts that are stronger than stock ? Any recommentations for aftermarked parts / options ?
I bash very hard.
Gravel pit jumping and also high speed runs on asphalt is my way to drive my RC,s
I will try Max8 esc and 2000kv 4268-motor, 4s at gravelpit pretty big jumps and 6s streetruns. Always full throttle almost
Steering i will use one strong high voltage 30kg digital servo SRT brand.
i need have this rig durable to handle hard bashing in mixed conditions.
What extra or option parts is needed ?
Wonder what The weak parts are in this TLR Typhon Roller ?
Some times i drive 30minutes from my home to great driving spots.
I need have parts with me because the long travel time with my 1/1 car sometimes to my sweet driving spots.
I don't want drive back home whit wrecked rig after couple jumps only , if i do bad landings or other mistakes.
Better have some option or extra parts so i can change them when im far away from home im thinking.
Please help me with some info.
Weak parts ?
Is there any better aftermarket options to this rig so i can avoid trouble ?
What pinion size you guys recommend to me ? i don't like change pinions. i wish have something that works ok with 4s and 6s
I will use dual 30mm cooling fans on the motor. And one better 40mm highspeed fan to my max8 esc .
I already have the combo and better fans by the way. Also the servo.
Just need buy the rig soon.
And extra parts, or optionparts. maybe a pinion too that is best for my needs.
Got couple extra pinions 17t, 21t M1, maybe these are wrong ? what pinion size you recommend ?
set up will be 2000kv 4286 dual highvolt fans motor mount my special with aftermarked highspeed fans,
esc will be the 150a max8 esc with highvoltage highspeed fan 40mm that i have already custom made to it. ,
Driving conditions are 4s at gravelpit , 6s at streetruns.
Pinion should be something universal that runs ok with both 6s and 4s .
i like to avoid change pinions altime.
I wish Keep it simple.
Not the best i know, anyways there must be one pinion that is ok size to both 4s and 6s.
Notice that i got high speed / high voltage custom fans to both motor and esc,
these helps the temps go down compared to stock fans. So i can go like 1 or 2t bigger easy in pinion size.
I bash very hard.
Weak parts ?
