Kraton Most often replaced screws on Kraton
Volcano
Japan
On your Kraton which screws do you find yourself replacing due to loss or fatigue?
I'd like to have at least those on hand.
FYI... I'm NOT looking for a kit :)
The ones most likely to strip are the metal to metal in the chassis. On a stock set up, there are fewer, as the chassis braces and center dif bearing holder are plastic. Motor/ center dif mount and steering post screws feel welded together the first time you try to remove them. Likelihood of damaging is high. Most all the screws will start to rust, so for appearance sake, you might want a complete set on hand as you start to do maintenance. Jennys RC sells full lots for different vehicles. Always nice to have spares.
