If you don’t factor motor or gearing sizes, the 2050kv will be faster. However, when factoring in gearing, they could be equal. There are many factors. Can size, voltage capabilities, gearing, weight, usage, heat, etc.Hey..
What the diferend between 2050kv motor to 1650kv motor?
The 1650 wil give me more power/moment?
Witch more fast on 6s ? 2050 or 1650?
Thanks
Thanks dudeTo my understanding, the kv count works as follows. For every 1 volt input, the motor will spin at 1000rpm x kv count. So a 2050 kv motor will spin a higher rpm with the same battery. A 1650 kv motor will handle the voltage much better so u can go with a taller gearing to overcome that rpm difference. Often times gearing high enough where you end up getting much higher speeds out of a 1650 than you will with a 2050. Someone can chime in and explain this a little better but I am confindent thats how it works.
ThanksIf you don’t factor motor or gearing sizes, the 2050kv will be faster. However, when factoring in gearing, they could be equal. There are many factors. Can size, voltage capabilities, gearing, weight, usage, heat, etc.
Basically you’re asking which tastes better, an apple or an orange.
