Wait how...i ran 8s 1250 on 29/46 on 6s mmx esc is was ripping all up n down the street motor stayed cool..I'd suggest max6 combo with 1650kv but you'll still have heat issues. I even tried recently running the Spektrum 8s 1250kv motor with 20t and it got as hot or hotter than the 2050kv when I ran 15t so was disappointed for sure. Also even with 20t it wouldn't hardly flip and didn't have near the speed as the 2050kv on 15t. I'd suggest getting a good 40mm fan like the game changer fans to keep it cool and run stock motor with 15t like I do.
Im not sure, I'm going to pop it open and see if something is up inside as I bought it used soWait how...i ran 8s 1250 on 29/46 on 6s mmx esc is was ripping all up n down the street motor stayed cool..
I bought a temp gun motor was108 esc was 103 not sure if I did it correctly but that was a 20 minute street bash then cool downIm not sure, I'm going to pop it open and see if something is up inside as I bought it used so
That's strange, my Hobbywing 1650kv motor runs cool as a cucumber, even without fans the hottest temp I ever saw was 158* and that was in 80-90* temps with the fans I'm around 120-130 after a bash session.I'd suggest max6 combo with 1650kv but you'll still have heat issues. I even tried recently running the Spektrum 8s 1250kv motor with 20t and it got as hot or hotter than the 2050kv when I ran 15t so was disappointed for sure. Also even with 20t it wouldn't hardly flip and didn't have near the speed as the 2050kv on 15t. I'd suggest getting a good 40mm fan like the game changer fans to keep it cool and run stock motor with 15t like I do.
I thought so too so I'm going to check solder joints and also open it up make sure everything looks good.That's strange, my Hobbywing 1650kv motor runs cool as a cucumber, even without fans the hottest temp I ever saw was 158* and that was in 80-90* temps with the fans I'm around 120-130 after a bash session.
What’s your gearing?That's strange, my Hobbywing 1650kv motor runs cool as a cucumber, even without fans the hottest temp I ever saw was 158* and that was in 80-90* temps with the fans I'm around 120-130 after a bash session.
Try using a 25t-27t on the 1250kv motor, it might be over heating because of that smaller gear...I run a 27t and have had no problems.I'd suggest max6 combo with 1650kv but you'll still have heat issues. I even tried recently running the Spektrum 8s 1250kv motor with 20t and it got as hot or hotter than the 2050kv when I ran 15t so was disappointed for sure. Also even with 20t it wouldn't hardly flip and didn't have near the speed as the 2050kv on 15t. I'd suggest getting a good 40mm fan like the game changer fans to keep it cool and run stock motor with 15t like I do.
Thanks for the suggestion I'll give it a try it's worth a shotTry using a 25t-27t on the 1250kv motor, it might be over heating because of that smaller gear...I run a 27t and have had no problems.
No they are about the same as stock.Are castle 6s systems good low maintenance (temperature wise) combos for this rig?
