Outcast Motor bearing washers
ArrmAh
Vancouver, Canada
  1. Outcast 4s
  2. Typhon 3s
I forgot the order and direction of these motor washers... Rookie move I know. Can anyone refresh my memory.
Thanks
Im taking one of my motors apart today to replace the bearings, if no one responds by then, I’ll let you know
Facing downwards its a spring not really a washer the 4s motor should have 2 and 2 brass shims and the 3s motor one solid silver washer 3mm hight and one spring
Thanks! searching thru the forums i may have found some inconsistencies with these motors and the type/number of washers and springs that are built with it. I wonder if this is why people are seeing the bearings go on the motor so much...
I don't think its that its the slipper clutch powder imo killing the bearing
