Logan's_Rcs
- Points
- 93
Recently, I asked TP Power to send an extra set of end caps for their 4060 line so I could test out some different bearings in my motor.. I tested the bearings by spinning my motor no load for 45 seconds at full throttle (Do not do this at max voltage of your motor, it will destroy it). After 45 seconds no load, I took the temperature.
First, I tested Acer Ceramics at 45 seconds. After 45 seconds, no load, my motor came to around 91 degrees Fahrenheit.
Next, I tested the stock NMB 688 bearings. After 45 (actually slightly less) seconds, the motor was at 101 degrees Fahrenheit!
Just by going to better bearings, my motor dropped 10 degrees in the same amount of time. There was no air flow around the motor, and all the ESC settings were the same. Only change was my bearings. I took the tests on different days inside and the ambient temp was the same. The motor started at the same temp both times.
I'm going to be looking for more bearings to test out in this regard, are there any other brands you guys would like to see me try? I was considering VXB and pro-motion rc ceramics next.
