Granite Motor connector fix
Currently reading:
1.21 Gigawatts
So I have bought three of these Granite Voltages- 2 for my sons and one for the neighbor (when my son broke his unfixable no-name rc truck). So far, only one diff outdrive has been stripped between the three trucks. The bigger problem with these is the motor bullet connectors always coming loose. After repeatedly having to reconnect the motor bullets, and having to resolder the wire onto the motor once, I figured out a fix.
The problem is the heavy ferrite cores that Arrma decided to hang off of the motor wires. Every jump, these are pulling on the motor wires eventually disconnecting the bullet or breaking the wire off of the motor.
The easy fix is to relocate the ferrite cores to the wires between the receiver and bullets (on the receiver side of the wire holder on the chassis. Then wire tie the loose wires between the bullets and motor for added security. Haven't had any issues on any of the three since doing this to all of them.
DRBNGR
Germany Baden Württemberg
  1. BigRock 4x4
  2. Granite
They are for interference supression. You might have negative impact in your radio transmission and esc function for example.
1.21 Gigawatts
They are "probably" not necessary, but since they can be easily repositioned to a location where they won't cause any problems, I see no reason to not use them.
DRBNGR
  1. BigRock 4x4
  2. Granite
Whell let's look at it from an economical perspective. Even if that ferrit costs arrma only 50 cents they wouldn't install it if it is not necessary. I can't exactly tell you what it is good for but i would rather look how to fix it in place than removing it.
slick2500
Community Leader
ArrmaForum Fan
Solutions
6
Rapid City, SD
  1. Outcast 6s
  2. Senton 3s
  3. Typhon 3s
My Ecx Ruckus and Torment had them from the factory and I noticed no difference when I removed them. To be honest I have no idea why they put them on, the Mega 4x4 models do t have them.
DRBNGR
  1. BigRock 4x4
  2. Granite
This is what my lhs writes about it...
... A ferrite ring is suitable for reducing unwanted electromagnetic interference. This is particularly recommended for lines from the receiver and to motors...
1.21 Gigawatts
Maybe it is the esc/receiver combo unit. Is the Mega a combined unit also?
slick2500
Community Leader
ArrmaForum Fan
Solutions
6
Rapid City, SD
  1. Outcast 6s
  2. Senton 3s
  3. Typhon 3s
2.4ghz isn't susceptible to this interference, it's a carryover from the old am and fm days that is why I said I'm not sure why they even include them on these cars anymore.
My Ecx vehicles have separate esc and receiver units so I doubt it. No the Mega is a separate esc and receiver unit.
RallyFanatic
Beautiful Oregon Coast
  1. Voltage
Looked up ferrite cores. It seems they could prevent electrical noise, hiss or other electrical interference. Since the RF equipment is so close, it is likely added to the motor as insurance to prevent any issues. Seriously, ferrite cores are used on almost every home appliance and most electrical devices. It was a staggering amount of information! So, I am going to leave mine in place and tie it down better.
slick2500
Community Leader
ArrmaForum Fan
Solutions
6
Rapid City, SD
  1. Outcast 6s
  2. Senton 3s
  3. Typhon 3s
All I know is that both of my Ecx vehicles had them and the darn motor wires kept breaking off, so I removed them, I haven't had any radio issues in the past 6 years and the motor wires haven't broken off since.
