Motor Cooling in this hot heat
Finessed
Montgomery County, Maryland
  1. Outcast 8s
Whats everyone doing to keep their motors cool in this hot weather? I live in maryland and it gets very hot here on top of the humidity almost every time the sun is shining especially from now until the end of September the heat is here to stay. Im open to all ideas/suggestions! That are better than the stock fan.
View attachment 152065View attachment 152066
Castle Creations 20 Series Dual Fan Shroud w/Fans
Reedy 40mm Aluminum HV Motor Cooling Fan
Works very well off xlx2 bec voltage and moves a lot more air than the stock fans (View attachment 152067). Original fans are press fitted on tapered plastic pins in all corners. Used a hook tool to carefully pull fans out without breaking fan blade covers then snapped all the plastic pins out of the fan shroud, roughed it up and hot glued the new reedy fans in.
Do you think the fan shroud would fit a stock arrma 8s motor?
