Note: This feature currently requires accessing the site using the built-in Safari browser.
I learn so much from these threads with specific problems that I haven't had yet.. very interesting. What's going on to make it cause that side effect? Can't get it's own gears to move so it pulls more voltage to do so, draining power from the rest of the car?Your servo is drawing too much power from your BEC. The servo is most likely failing.
Yup it's junkoServo is on its way out..![]()
Even setting the end points stock servos on most of these rigs don't last long especially if they bash hard .asking to much of them cheap servos .just take it out spend 30 or 40 on a decent 25 kg and you'll be all setMost likely that servo, get it out of there before you blow up that ESC.
#1 easiest first thing to do on an RC is set those steering endpoints. Will make the servo last as long as it can and reduce current on the BEC (ESC).
Its like rolling the dice.Even setting the end points stock servos on most of these rigs don't last long especially if they bash hard .asking to much of them cheap servos .just take it out spend 30 or 40 on a decent 25 kg and you'll be all set
Its definitely a quality issue..let's face it..servos offer a very important roll in being able to use your rig.i think that quality on stock servos are designed to fail premature so you go back and buy another.thats if it fails after warranty..most do and in this case they have to replace it .and I'm sure they hope you lost your receipt.either way it's a easy fix and easy to replace.just hope it doesn't fail on you when you need it most.then the damages might be worse than just a servo being toast.behind my local high school we have a nice long track.people go there and myself at times to do speed passes.on both ends of the track there are brick walls .I've seen these guys get brave and turn as close as 5 feet before the wall and a few never made it because there servo gave out..they left with a pyle of plastic and broken parts ..Its like rolling the dice.
I have one on my Granite (an older one) that probably has 20+ packs on it.. It is fine, I have seen others literally not even get through 1 full pack. I think its probably just poor QA/QC.
35 kg imo is to high.try 25kg.you should have no issues with power supply from becIt’s a stock servo. I have beaten it pretty hard and it’s been submerged. Is a 35kg too much for the 3s line? It’s the blue one everyone talks about I had set aside for another machine. Stock esc
Appreciate all the info.![]()
Are you sure it's 35kg stock?35 kg imo is to high.try 25kg.you should have no issues with power supply from bec
Yeah I was like 35kg stock in the 3 s line there is no way .I even checked the specs and it's 7kg so 25 would work awesome.thats what I'm using in my BRcc .don't put that 35 kg in it.Cooking dinner sorry should have provided more context. It’s the stock servo in there now having issues. I have a 35kg unused I can throw in it just don’t want to mess up anything as I’m still learning about the electronics on these things
I’ll try turning that setting down all the way as well and give it a run tomorrow. Easy check![]()
The 35kg one you have should work fine. You will need a 25T servo saver.It’s a stock servo. I have beaten it pretty hard and it’s been submerged. Is a 35kg too much for the 3s line? It’s the blue one everyone talks about I had set aside for another machine. Also have the hot racing servo saver to fit that servo. Stock esc
