Note: This feature currently requires accessing the site using the built-in Safari browser.
yessirIs that the 4985 1650kv???
From what I read from old threads, gearing is 16-20 pinion to 50 spur?
haven't found what fans to buy, any proven fans is easy to fit?
Hobbystar makes a 4585 1800kb that pairs really good with the Max6 as well. I have it in two of my rigs and it’s a little fasterhello, been reading old posts, what is considered to be _the_ motor upgrade for Notorious/kraton 6s blx, if I want to stay on 6s. Thanks
Also if you want to add info about common/proven gearing, thanks a lot
That actually sounds like a great idea too. I bet it will shave a little weight too if you care about that sort of thing.Hobbystar makes a 4585 1800kb that pairs really good with the Max6 as well. I have it in two of my rigs and it’s a little faster
Like stated above Max6 (1600kv-1750kv-1900kv motor) 16T-18T pinion depending how you bash and motor temps. Temp gun in hand to evaluate.hello, been reading old posts, what is considered to be _the_ motor upgrade for Notorious/kraton 6s blx, if I want to stay on 6s. Thanks
