Stack15
- Macon, Georgia
- Fury
- Granite
- Mojave
- Talion
- Voltage
- 4x4-Mega
can someone recommend a good motor heatsink for the typhon please? Thank you.
I’m using yeah racing heatsink and dual fanscan someone recommend a good motor heatsink for the typhon please? Thank you.
Yes they do. I used a yDo those fans plug directly into the receiver?
I plug it in the #3 slot on the receiver.Do those fans plug directly into the receiver?
Not sure which switch on the transmitter operates the #3 slot but when I plug the fans in and turn on the ESC the fans work.That’s where I am confused. What triggers the three slot to be on? I was thinking a cable splitter in the two slot maybe. That way when the motor is engaged the fans come on. Right ? Would that work?
So far I’ve used A y and plugged the fans in the number 3 slot of the receiver in my Kraton, Outcast, Talion, typhon and Senton. Everything worked fine when you turn on the switch.That’s where I am confused. What triggers the three slot to be on? I was thinking a cable splitter in the two slot maybe. That way when the motor is engaged the fans come on. Right ? Would that work?
