Everyone I have talked to says the Castle Fan does nothing.Thanks Raji, ordering it now. I am not impressed with the Castle fan.
They are Vantec Tornado fans? I had some of those in a pc case years ago, they were load AF but moved a lot of air.You welcome.
You will love it they are a real tornado Fans (they worth the name)
In the beginning I was surprised by there sizes, but they can blow the whole car. you can feel the air near the receiver box and the Servo.
tell me your opinion when you instill it.
I will post some pictures soon.
I see guys on Facebook running the Yeah Racing twin fan heatsink off the esc without any issues.Has anyone had any issues with the fan plug on the esc having to run two additional fans? I am having a hard time finding any documentation on how much power that plug can supply, or if it is in the same power circuit as the built in bec? The main reason I am concerned is because (like many of you) I already run a more power hungry servo and I am worried about over taxing the secondary power output from the esc.
How durable are the yeah racing fans. I am currently using the hobbywing heatsink and fan combo but the fans seem to break and I have to replace every month. I do a lot of jumping and backflips so I am sure that doesn’t help but was wondering how the yeah racing ones are.I see guys on Facebook running the Yeah Racing twin fan heatsink off the esc without any issues.
About the same. Most toss some WTF fans on it. However there aren't too many fans that can hold up to long term jumping ?How durable are the yeah racing fans. I am currently using the hobbywing heatsink and fan combo but the fans seem to break and I have to replace every month. I do a lot of jumping and backflips so I am sure that doesn’t help but was wondering how the yeah racing ones are.
Just a PSA, if your motor is running hot enough that it needs a fan the proper solution is to gear down. All a fan is doing is correcting the symptom
If adding a fan brings the temperature down to a safe level then that would be considered the "solution". The "symptom" was excessive heat due to increased load from gearing. This is a perfectly acceptable way to reduce temperatures.
It's the same reason your ESC has a fan blowing on it.
