TheBeardedGiant
- Vorteks
Im using the stock 550 motor and I recently switched to metal gears and added 4x4 upgrade to my Vorteks, and since then I've smoked two motors. The first motor after upgraded to the 57t .8 mod spur gear, I was using the 15t .8 mod pinion and I assumed the gear ratio was too high. Got the motor replaced and switched to an 11t .8 mod pinion and smoked the motor again. I've made sure to have a proper gear mesh, and I'm not sure what could be my problem. Is the motor just not capable of pushing the 4x4 and the metal gears?
