UPPERDECKER
- Mojave EXB
After some lengthy reading across the corners of different rc forums, I'm having difficulties trying to wrap my head around the concept of kv in regards to heat and gearing.
I know higher kv/more rpms per volt, higher volts/less amps per same load, and less amps/less heat. So what if volts and load is the same? Does going to lower kv, and gearing up to regain some wheel speed increase load/generate more heat then less load (smaller pinion) on a higher kv? If I lower my kv but keep the volts and load the same I should run cooler, even at maximum throttle, correct?
My concern is more about heat than speed, I have more than enough wheel speed with the higher kv and find myself turning max output down but temps are high. Not dangerous, but not comfortable. I imagine I would be able to use more of the available power with the lower kv and the same load, but does that generate less heat?
I read that motors of the same size can will generate the same power/torque just at different volts/amps, but my volts and load are staying the same, so amps is the varying factor. Following the formula I should be pulling less amps (heat) than the higher kv, but will that be negated by increasing my max power output to regain wheel speed instead of a bigger pinion (more load).?
Lot of questions going on here, sorry. I'm not great with words either but I hope I was able to convey my thoughts well enough.
