I’ve got 2 pps motor mounts in my trucks^^^Yes PPS all the way. The best motor mounts I've seen so far.
Yeah, The OP is using a 56mm can motor. FWIW. Just not sure what his fitment issue is. Gear spacing, motor diameter issues, or both. ? He wasnt clear on this.
Or just confused on what gear will run best?
It kind of looks like that in the pic@Ajag, is it me or the picture angle, your Pinion appears off-center with the Spur there?? The TP motor picture.
Probably me, you tend to be meticulous in your builds.
Nice K8S btw.
ThanksWhat brand of pinion and spur gears are those? That's a really good-looking truck!
Ajag,I’ve got 2 pps motor mounts in my trucks
One in the outcast 8s running a castle 2028 with 44t pinion/47t spur
the other is a kraton 8s running a tp power 5860 (1070kv) running a 35t pinion and 47t spur
I would recommend pps
I’d probably go with the castleAjag,
If you had to choose from castle or to power motor which would it be?
The 2028 castle motor specs are nice. Plenty of power and runs cool. I’ll be trying the 1100kv once it goes back in stock.I’d probably go with the castle
I have a castle 2028 in about 6 or 8 trucks and about 20 tp power motors in various cars and trucks and I love the power of the tp motors but they run hot.
the castles make great power and run much cooler overall
for a speed run car it’s not bad..but for a basher the castles are my first choice
Where did you get that body I know that didn’t come like that looks good.Thanks
That’s a saga custom 35t mod 1 pinion
The spur is the stock arrma 47t
here’s the truck with the body on
I painted it myselfWhere did you get that body I know that didn’t come like that looks good.
very nice skills sir...I painted it myself
Very nice work. You have skills.I painted it myself
Will it fit a hobbywing 800kv with 39/39 gearsWhat brand of pinion and spur gears are those? That's a really good-looking truck!
You put IC5 Connectors on an XLX2 ?!I’ve got 2 pps motor mounts in my trucks
