GaryC
3s typhon motor mount? I'm tired of messing with it to get gears to fit correctly what to do?
Can I just mod it? Suggestions?
I have heard people say those are too tight though but I have no experience with them at all so I don't really knowyou could buy one of the earlier 3s motor mounts with fixed mesh - it has pre-drilled holes for mounting the can so that the mesh with the corresponding pinion size is perfect. Otherwise, loctite on the mesh screws and maybe a small lock washer?
Ya I didn't mean to say 6s on 3s...but I'm just having issues fitting bigger gears without it giving me an issue...I'm trying for speed runs and all around the mount just isn't reciprocating lol...6s motor mount is entirely different than the 3s, what problems are you having?
If its possible that would be interesting but I don't see how it would be
Well I'm running a 6s motor, going for speed runs and the 3s just doesn't accommodate, mesh is too tight and so on...you could buy one of the earlier 3s motor mounts with fixed mesh - it has pre-drilled holes for mounting the can so that the mesh with the corresponding pinion size is perfect. Otherwise, loctite on the mesh screws and maybe a small lock washer?
Glad you got it figured out!!Stock...I had to dremel it a bit. Good now
Ya. Had to dremel a tad
