BROWN LETTUCE
Just purchased a 1/8 kraton exb along with the max6 4985 combo. I'm a Newbie so bare with me. The included motor mount screw holes don't line up with the motor hole pattern. What mount do you suggest or am I missing something?
Welcome to the forum! Also pictures might help with this question. Hope you get it sorted out quickly.Just purchased a 1/8 kraton exb along with the max6 4985 combo. I'm a Newbie so bare with me. The included motor mount screw holes don't line up with the motor hole pattern. What mount do you suggest or am I missing something?
Those holes are the ones you use to mount the motor. The outside holes should have screws in them and they are used to hold the motor together. Make sure that you use blue thread lock on all and any screw going into metal.Thanks for the quick replies, I will post pics tomorrow when I'm home. The mount will line up with the 4 inner circle holes that don't have screws but I don't think the holes are threaded. Like I said I'm a Newbie, if someone has a pick that could help me.
ThanksThose holes are the ones you use to mount the motor. The outside holes should have screws in them and they are used to hold the motor together. Make sure that you use blue thread lock on all and any screw going into metal.
Mine didn't come with a pinion either. But my mount screws were in a little bag with the servo horn screw.Problem solved, first thing my exb roller didn't include motor mount screws or pinion. I didn't realize the mount screws to 2 of the inner screw holes.
Totally optional. Top motor mount screws are supplied with the EXB. Some like the button head with washer is a better step up...optionalProblem solved, first thing my exb roller didn't include motor mount screws or pinion. I didn't realize the mount screws to 2 of the inner screw holes.
Thanks
Gotta love arrma changing stuff, mine use a big flanged screwTotally optional. Top motor mount screws are supplied with the EXB. Some like the button head with washer is a better step up...optional
quality control for the win. It should come with a 12t pinion and the motor screws. i had everything in mineMine didn't come with a pinion either. But my mount screws were in a little bag with the servo horn screw.
If the front endcap doesn't go only in one specific way. You can remove the bolts and spin it around. My 6s stock motors will only have the wires coming the right way like how they were designed if i screw the endcap correctly. I use a permanent market to know
i saw the tlr coming with those screws+washerIt does come with those flanged button heads screws he just changed his and added washers. I did the same thing, I always change out every screw I can to cap heads.
Not the one i saw at my hobbyshopNo, the TLR Typhon still comes with the flanged button head screws.
Arrma keeps making changes each new batch. The new exbs apparently come with a washer under the button head who act As droop screws.OK ... per the two I have and the exploded view/drawings for the TLRT, it's still the button head screws. But hey, if they are upgrading to socket head screws, all the better.
