I have a Notorious that I only got a couple of weeks ago. I am not happy with the mesh and I want to clean up the motor and the pinion and spur. One of the motor mount screws came loose easily but the outside one is in hard. I know they use too much loctite and I've seen many posts about stripping them. I don't want to do that.
So what is my best bet to get this out safetly? Soldering iron on the screw head to heat it up and then back it out carefully?
Also - why do they expose the spur gear with a hole through the bottom of the chassis? Sure it needs clearance but it seems silly to build it in a way that lets so much dirt and crap in on the spur gear and around the motor.
