Hi guys I’m not too happy with my standard motor mount and want to upgrade it. Any ideas/experiences? I like the look of the hot racing one so if anyone is using or has used it some feedback would be awesome.
Don't you have to shim stuff to get the hr motor mount to work? Not sure but I read that the center diff needs to be shimmed.
Odd. I didn't notice any need for it. Needing to sand the bearing race to allow the bearing to fit in there on the motor mount side especially is needed though. I really should have sanded mine... going to be a bear getting that bearing back out.If you I've both the HR motor mount AND the HR center diff brace then you need to shim the play out if it.
I had to shim both hr mount and front brace installs on my kraton and senton builds. You can check out post #27 in my senton build here: https://www.arrmaforum.com/threads/anyone-running-leopard-4092-1730kv-on-6s.7869/Odd. I didn't notice any need for it. Needing to sand the bearing race to allow the bearing to fit in there on the motor mount side especially is needed though. I really should have sanded mine... going to be a bear getting that bearing back out.
