Typhon Motor mount
DAMO
I guys I’m running 18t pinion not much more adjustment left for bigger gear what mods to motor mount is required to run bigger gear
There's enough room to go up another 5 teeth on the pinion using the stock motor mount. If you still need more then I'd start looking at dropping teeth on the spur gear to a 46t
Doesn’t look like much room but I’ll give it a go thanks
Top is almost at the max but the bottom screw has quite a bit more adjustment left in it
