Bruce banner
The Hulk
- Amsterdam (Holland)
- BigRock 4x4
- Granite
- Notorious
- Typhon 6s
- Voltage
Does this look familiar to anyone?
Do you mean the motor module?Does this look familiar to anyone?
I mean the Motor...... It get completely stuck ?? I mean it's Guarantee?..... But want to know if I'm the only one, or is it CoincidenceDo you mean the motor module?
I'm still not sure what you mean. Is this a 3s Big Rock Crew Cab?I mean the Motor...... It get completely stuck ?? I mean it's Guarantee?..... But want to know if I'm the only one, or is it Coincidence
Yep..... That's the one??I'm still not sure what you mean. Is this a 3s Big Rock Crew Cab?
So when you move the red stopper that sits under the center driveshaft and lift the tab on the motor module, it won't pull forward and out?Yep..... That's the one??
Mesh is to tight?I consider to get this vehicles as well, did you found out what caused the issue?
Mesh is to tight?
https://www.arrma-rc.com/part/AR310898So you cant adjust it out of the box? Where can one get adjustable motor mount?
preset mesh design out of the box... upgrade is needed..... Anyone else have better alternatives? This reminds me of the TRX-4 motor mount. Preset mesh positions based on pinion size. But the TRX-4 actually does work! Can't believe I just said that.So you cant adjust it out of the box? Where can one get adjustable motor mount?
Thanks for showing me, but how can you adjust the mesh when you change to smaller/bigger gears if you have a stock car, no one have the mount in my country so if i buying it it’s a must have before i start running it?
What country are you in? Does ebay work for you? You can also get one from Hot Racing that works just as well.Thanks for showing me, but how can you adjust the mesh when you change to smaller/bigger gears if you have a stock car, no one have the mount in my country so if i buying it it’s a must have before i start running it?
Every truck have some weakness and i appriciate to solve them before i start using it when i get it
