parcou
Hospitality Award
Rig of the Month Winner
- Memphis, TN
- BigRock
- Felony
- Fireteam
- Granite
- Infraction
- Kraton EXB
- Talion EXB
- Typhon TLR
- Vorteks
This is for my Fireteam but would be no different if it were my KEXB 6S on this ask.
I never ran the stock 12T pinion. One the first run and beyond, I purchased the Tekno 12T pinion with the M5 bore. I did the same for my KEXB since the 20T pinion would back off but has not since I went with the Tekno for the KEXB. Think I read someone else had this issue so I went with the better bore off the bat.
New stock motor so clean shaft. I also cleaned the Tekno 12P set screw with CRC electronic cleaner I've used for years to clear screws before adding loctite. I used 243 threadlocker and I added I good about enough I had to clean the bore hole around the screw once it was screwed down. I do not understand why it backed off with this upgraded pinion???
Only negative I have with the mesh the motor mount slider is pushed over as far as it can go. I have more room between my spur gear mesh or tick sound. I would like for it to be a little closer. More rock in it between gears than I would do. However, it has bashed fine no issues until I noticed wiping clean the motor mount I moved the pinion on the shaft.
Any suggestions? Thx
