My motor sounds weird and gets hot on 50%. And it's stuck there and can't remove it any easy way?
shaft
I can't come off it's pulling the bearing down. I will try the vise trick wish me luckUnless the end of the shaft is peened over, it should come out. Clamp the end of the rotor in a padded vise and pull on the can if it’s giving you that much trouble.
No I won't come off even with that.Unless the end of the shaft is peened over, it should come out. Clamp the end of the rotor in a padded vise and pull on the can if it’s giving you that much trouble.
No nothing. Don't know what's happening.Push it back in position and check for any peening/burrs on the motor shaft that is keeping it from passing through the inner race of the bearing.
You could brute force it but that might result in needing to replace the bearing.
It's probably bent. Still won't come out.I would just tap it out with a mallet or small hammer. New set of bearings is a good idea anyway. Shaft could be slightly bent or chipped preventing it from sliding through the bearing.
If it is getting hot and overheating the bearing is more than likely toast already.Push it back in position and check for any peening/burrs on the motor shaft that is keeping it from passing through the inner race of the bearing.
Stop wasting your time on that motor. It is junk already.
Just Buy another.
Just don't neglect the new one. Or you will end up with another Paper Weight.
New motor it is. This one was overvolted anyway. Time to actually buy a kraton motor.Th shafts are junk.
The BB's are stuck because the BB's inner race started to gall out onto the shaft. You can try your luck with a new set of BB's there.
Been there with this scenario. Motor/BB's weren't maintained enough.
If the Shafts cannot be cleaned up well enough or are too worn where the BB's sit, the new BB's will have slop at the shaft. Motor armature will be shortlived anyway.
It's your call. Try new BB's or just a new motor.
I always smear a bit of grease onto the shafts befre installing New BB's. I find this can prevent galling when the BB's do fail. Motor's are all about protecting the armature. They are NOT replaceable as a part, 99% of the time
Will do in a year or two I'm taking a break from rc parts buying because I wanna save up for a computer. Hope nothing breaks till thenHey you got your money's worth.
Just maintain the new one a bit better.
I can't overemphasize the value of going Ceramics with Motor BB's. Even with a new motor out the box. They also need the same maintneance. Just that they run cooler and have more precision. Worth the few coins more . Motors should literally last for years and years this way. Just by cleaning, lubing and replacing the BB's periodically.
Jim's BB's and TRBRC make decent Ceramic or standard Chromium ABEC rated Motor BB's.
