RCBro80
So, I've had my 6S Kraton since October, and have never found motor temps to be more than warm (running the stock pinion and tires), likely because of the cold temps here in Canada. As the temps have been rising a little I've been noticing motor temps are quite hot when running on 6S (I don't have an IR temp gun, but I will say 160F ish). From what I read, this is about the safe limit for brushless motors. Is this true?
If so, why is it that I see guys gear up their rigs without a motor heat sink/fan even in seemingly warmer climates. I also find it strange that the 4S and 8S models ship with a heatsink, but not the 6S.
Obviously it can't hurt to add one, but is it required? What kind of temps do you guys see and what is your comfort level?
Thanks!
Thanks!
