Outcast motor upgrade
Thanks....Have you tried the Turnigy motors?? I have their batteries or at least i think they are the same company. They are pretty good. Any thoughts
No I've seen them I've got 2 cheap surpass motors an they RIP.STOCK IS 3668 ARRMA MOTOR.I RUN 4068 2650KV WITH 22T.THEY ALSO 2050KV,WOULD BE BETTER FOR OUTCAST.like a 40$ motor
I didn't think they would be any good at tht price. What about the esc? Are they any good
It rips,I run it on 4s mostly.ran couple packs on 6s 75mph then kept going airborne.i run blx185,you got blx120 in 4s outcast 4068 would run good together
Definitely would run faster, cooler,an could take 6s.OR GET A STOCK 6S MOTOR LIKE 1 IN MIDDLE.BOTTOM MOTOR IS STOCK 3660 SENTON BLX 3S.
Hey, so the surpass motor finally got here...I ran it today on 4s with a 13t pinion and only manage to get 43mph. With the stock motor i would get 54mph. Im thinking i have the wiring wrong. And it also run hot. Any suggestions?
I got a 2050kv. I think i might need to gear up...i have a 22t pinion ill throw in. Hopefully temps go down
