Kraton Motor wires exposed..still ok?
stevenwm
Central Valley Ca
  1. BigRock 4x4
  3. Mojave
  4. Senton 3s
  5. Typhon 3s
  6. Vorteks
Hey guys hope you’re all doing good
I was putting a new motor mount on my motor
The manual says longest screw can be used is 3/16
When I was screwing in a before It got tight I heard a little pop
When I took screw out I noticed now wires are exposed
Did I screw in to far?
I know for sure it was no longer than 16mm
Is this ok to use with these wires exposed
Thanks guys
where did it go when you heard the pop? the plug I mean
If I could send it back I would, otherwise throw a screw in there seal it and run it
Nothing was hooked up I was just screwing in the mount
You can see there’s a little cover or seal in the other holes
I believe it was the little seal that popped when I was screwing it in ..like I went to far
Not sure if that makes sense 😁
Yeah it does, Its that hot glue stuff, there are some guys on here to take the spool out of the can and clean it and put some stuff on it, don't quote me on it lol. hopefully they pop in here and help ya out.
If it be me I send it back, but you wanna run it I bet lol
but that hot glue is hard, and maybe some crap is inside the can now. idk either but it's sealed for a reason.
I don't think its hot glue. If something is now inside the can it will fall out once the motor is taken apart
Remove the top half
Yeah I want to run it !! 😂.
Sent horizon a message with pictures will see what happens
Not really expecting them to take care of it
So if it’s ok to run ..I probably will
If it only broke the yellow film and didnt thread into the windings should be okay
Thank you
Not sure if went into the windings
Wondering what’s the worst that can happen?
I’m not sure if I did thread into the windings
If I did a little could that affect anything
I appreciate the help I really have no idea how these motors work
Thanks brother 🤛
I’m definitely going to see what horizon says
realistically they should warranty it
The manual say you could go up to 16mm
And That’s what I used
I guess I just need to be patient and see what they say .. Before I tear it open
Thanks again
what Motor you got?
Hang on i take one out of the can, I got a 2050
Front
you fine, just take the front of and kinda clean the debris out
Magnet is strong and make sure you remember where the washers, spring and sleve go
Back together, make sure the shaft is spinning not smooth but easy and no Grinding or any noise.
make sure the curved side of the spring/washer is facing down and the spacer with the bevel up to seat into the bearing
If you pull on the shaft make sure there is no play anywhere up and down
Just to make sure, you are not actually using a 16mm long screw are you? The manual says 3/16 inches which is about 5mm!?
Edit to clarify: The 5mm or 3/16 inches is the depth of the screw holes on the motor. So use a screw that does not stick out farther than 5mm from the back of your motor mount and you're good.
