Hector_Fisher
I've got the standard 6s package (4074 motor, 150a firma) in my kraton exb. I need a motor for my MT410 build since the 2650kv I had planned originally for it is too high, and since I'll be running copperheads on it. Is the 2050kv from the kraton a good choice for that mt410 setup (running 4s on lowest pinion possible--15t)?
Could I run into heat issues with that? And if I use that motor in the mt410, I'd need a motor for the kraton...
I like the idea of doing a 4092 in the kraton and then gearing for torque, but all the 4092s and 4082s come with 6.5mm bullet connectors which don't pair with the firma 150a (4mm bullets). I don't have the budget for a max6, otherwise I wouldnt be posting this in the first place
Either the swap is a good idea for the mt410 and I buy an upgrade motor for the kraton (preferred), or leave the kraton as is and find a suitable motor for the mt410 (cheapest option). I'd like to upgrade the kraton motor while I have a reason to, but I'm struggling with this one. Thoughts appreciated.
