vman38
Hi Guys
I have installed the Mugen MBX8 straight cut diffs all round in my modified V1 Kraton. Was getting tired of busting the side gears in the Arrma diffs. I am running the Leopard 1480kv motor 16 t pinion and the 185 blx esc with cap pack on 6s.
Had to buy different bearings to install the Mugen input gear in the Arrma gearbox and dremmel a bit off the back face of the input gear to get it sitting flush to the bearing so that it doesn't rub on the diff case. Everything now fits perfect.
I had my first test run last night and - wow man that thing rips! I was having great fun for about 20 mins until I had one bad landing and the front rhs diff cup split off!
Looks like the Mugen cups are hard but brittle. To be fair it was my bad for the landing and also hopefully it was just a weak drive cup. I have ordered 2 more cups to be here in a couple of weeks so will have another go at it.
I will post more details for you guys if I have any success in getting this sorted and tested for a good few weeks.
Do any of you guys know of a stronger diff cup with a 6mm shaft that would fit the Mugen diff?
Thanks.
Thanks.
